- Points
- 218
- Kraton 6s
- Typhon 3s
Evening all. Could someone please tell me if I can swap chassis to the EXB one. Not sure which one I've got but after changing the front diff housing. Found out that it's bent
its supposed to be like thatEvening all. Could someone please tell me if I can swap chassis to the EXB one. Not sure which one I've got but after changing the front diff housing. Found out that it's bent
Cheers chaps. Think I've finally found out what's wrong with the car after months of replacing bits.
The diff housing was cracked!Never even thought about the housing and was more focused on the diffs themselves. Ordered a new front shock tower and fitted the brand me houses today.
Fingers crossed this is the end of a horrible start![]()
We've seen what you do to chassisBash, repair and repeat. That's all in the name of the game. I've broken so many gearbox cases on my 6s rigs.
doesn't look too bad....not!
make sure you shim your diffs rightCheers chaps. Think I've finally found out what's wrong with the car after months of replacing bits.
I went thru the same thing. Couldn't tell it, till after I completely removed it, bare. And compared to a new one. The ring gear had contacted the inside. Found it after I cleaned it all up. It was just crooked, I guess.Not sure if it's that but what else can it be. Replaced all diff cases, motor mount and pinion![]()
Have you replaced the housing with a plastic one or gone metal?
Thinking to go down the aluminium route but don't fancy paying 40 odd quid for 1 housing at the moment
