Kraton Compatible Body Database
Thread starter #1
Nitr0EngiEx
Likes
69
Hi guys, I wanted to start a list of bodies that fit the Kraton. I will keep this list updated over time.
Please share pictures and links to the bodies you have installed on a Kraton with any needed supporting mods and fitment notes!
1.) Chevy Longbed from Proline - No or minimal modding needed
https://www.prolineracing.com/bodie...x-e-revo-revo-3-3-mgt-long-bed-clear-body.asp
2.) LFR, Lead Finger Racing MBXT Body, no modding needed
http://shop.leadfingerrc.com/Strife-body-clear-for-MBX-7TR-LFRT4019.htm
3.) Traxxas Emax body
https://www.amainhobbies.com/traxxa...tk_HNlDJnAvQe5iu6x6p7Zwf0q5C4MChoCLsoQAvD_BwE
4.) 2014 proline silverado body fits well.
https://www.amainhobbies.com/prolin...o-monster-truck-body-clear-pro3430-00/p387184
5.) Summitlink VW baja
https://www.amazon.com/SummitLink-Volkswagen-Unpainted-Stickers-Thunder/dp/B01I9OTIEM
Thread starter #3
Nitr0EngiEx
Likes
69
Yeah I think several can be made to fit as you can cut the holes as you please, but I was hoping to see a database with all of them listed to make faster decisions and save time searching
sevin7
Likes
64
Marietta, GA
Outcast
Anything that fits the E-Revo should likely fit as the wheelbase is about the same. You need pro-line extended mounts for some bodies like my Jeep body (which would likely fit but look a bit off due to shorter wheel base). If you look at 8th scale monster truck bodies on pro-lines site and then look at the specs of each it tells you the wheelbase which is the most important measurement for making it fit the Kraton (14.84" wheelbase). Any body with a wheelbase that is within 1" of the Kraton's wheelbase should fit pretty well. Also a lot of bodies will require cutting out the back if you want to keep the wing.
Thread starter #10
Nitr0EngiEx
Likes
69
well this is going to be the thread, rename it appropriately and sticky it please.
I will keep a running update of the bodies in the original post as fits are confirmed.
Guys, will you please post links to the bodies you have used with notes on mods needed to install, and any fitment notes. Pictures are great too.
thanks guys
@WoodiE
Bigdickdaddy
Likes
Kraton
I checked when I got home and it is the stock emaxx body that fits well. Also the summit body fits really well.
Thread starter #17
Nitr0EngiEx
Likes
69
Drtybird
Likes
74
Kraton
These kraton bodies are they set with factory crash bar or esc mod mount on center diff
M Kraton 20
EbbTide Kraton 20
Mr.Duke Arrma 4x4 Mega & BLX 26
Z Kraton 5
Similar threads
