Awesome rebound Dub - way 2 GET BACK UP. The night I got my 1st 1/8 scale I decided to race a Ford 150 after a few glasses of wine. Well my Earthquake 8E shot under the bottom of the F-150 and got clipped by the right rear tire. Bunch of new parts - I was determined but that was a hard nights sleep boy.I have an original Kraton that came with the hubs with the thin outer bearing support that cracked. Arrma beefed up that part and I am running those. Now if you have the V2 Kraton, I believe they use the Tailion hubs which are wider and, in turn, use a shorter hex. I will probably upgrade to those if I have issues with the revised V1 hubs.
I used the Fast Eddy rubber sealed bearing kit and only used a light coating of grease (on the outside) when installing them. I never took them apart and greased the actual bearings. I'm not sure if you can even open them up to be honest...
And like you said, they're not $$$ so just pop in a new one when they go bad.
Looks realy cool !
Great job.
Hi
Hi
Do you know which aftermarket company sells similar bearing kits for the nero?
I went on both fasteddy and avid sites and they don't have anything for nero.
Looks great! Two questions:
1. Which proline extended body mounts did you get and was it a direct bolt on to the shock towers?
2. What body is that? (it looks awesome!)
Thanks!
