On the V5 you can take a body reamer and make the hole in the aluminum cap just big enough for the flange on your pivot ball to go through. After that you can shortenThe front dogbone keeps jumping out of the Kraton input shaft cup when jumping.
I drive a 6s Kraton V4 and my buddy a V5. Same problem.
Take out the spacers?
What do I do?
I see this solution a lot. In my case the dog bone always pops out on max compression. How does droop fix this?Setting your droop properly will help mitigate this.
cheers,
kev
He changed his post to say bump stop which is correct.I see this solution a lot. In my case the dog bone always pops out on max compression. How does droop fix this?
The Nylon washer idea was great! I just bought an assorted set from amazon for like 6$ and added 5 of them to my front talion shocks as I was also having this problem. Was also going to add it to my kraton too but I recently changed the springs to be much stiffer which I think already helps to stop this. I'll probably do it anyway just to be safe lol.I used four M4 1mm nylon washers on each shock rod. So 4mm in total. This limits max shock compression.
Also screwd the pivot balls in as much as I could, and still wheel camber is ok. Droop screws also set.
This looks to fix the issue on my Kraton 1/8 EXB.
Did some serious long jumping this sunday, and no issues or broken on the car.
I use stock Arrma arms.
But I have some RPM lower front arms and when compared with the Arrma it looks like the RPM arms are 2-3mm shorter.
Some Youtubers say that using the RPM lower arms fix this issue, so if they really are 2-3mm shorter that is maybe why.
But I just did a quick comparison, so I could be wrong here.
Of course you can remove the spacers on the Arrma arms also, I did not test that fix.
A note here: Just got a new Arrma Kraton 1/8 EXB. And that car did not have any plastic spacers inside the upper pivot ball.
Just a thin metal washer. My first Kraton 1/8 EXB had two plastic washers I believe. So Arrma looks to have made some updates to the EXB here.
The metal washer is thinner than the two plastic washers, so looks like Arrma have tried to fix this issue on newer EXB's... maybe.
