BLX Kraton drag
Discussion in 'Kraton' started by Pistol87, May 11, 2018.
  1. Pistol87
    Pistol87 Well-Known Member
    Jan 4, 2018
    24
    6
    Eden nc
    Arrma RC's:
    Kraton
    ok I have a kraton I want to set up drag I have a mamba monster x and Leopard 1600kn motor what’s a good gearing to start off with? And any tip that might would help ty in advance
  2. Headbangerfacerip
    Headbangerfacerip Well-Known Member
    Oct 15, 2017
    106
    64
    Cream Ridge New Jersey
    Arrma RC's:
    Outcast
    It depends on everything.... How far of a distance? What size battery? Are you still running the stock pinion and spur? I believe a kraton is 12/50 not sure tho. Just know the higher/bigger the pinion the more top speed but the lower the acceleration.
    ABRedneck likes this.
  3. Pistol87
    Jan 4, 2018
    24
    6
    Eden nc
    Arrma RC's:
    Kraton
    132ft distances 5200mAh 50c battery 17t pinion stock spur
  4. Headbangerfacerip
    Oct 15, 2017
    106
    64
    Arrma RC's:
    Outcast
    I guess your running 6s? I would put tge biggest pinion in that i could till i noticed a lag of the line. Then i would use the castle link to mess with the punch so it would keep the front end down and make all power about 50ft out. You might get beat off the line but you'll walk around them once that big tooth starts turning.
    Pistol87 likes this.
  5. Pistol87
    Jan 4, 2018
    24
    6
    Eden nc
    Arrma RC's:
    Kraton
    Man thanks that’s the best advice I got since I been thinking bout doin this every one else act like they don’t want to give me any advice
  6. Headbangerfacerip
    Oct 15, 2017
    106
    64
    Arrma RC's:
    Outcast
    Eh. People only like to talk about what upgrades they have and what weights they run lol im just playing... This forum is actually very helpful and have alot of good advice. I'm sure you'll meet good people soon. In tge mean time keep an eye on those temps ;)
    Iamtheoutcast likes this.
  7. Pistol87
    Jan 4, 2018
    24
    6
    Eden nc
    Arrma RC's:
    Kraton
    Whats
    normal temps
  8. Headbangerfacerip
    Oct 15, 2017
    106
    64
    Arrma RC's:
    Outcast
    Are you asking? If so im pretty sure castle is like 180 max but i would double check. Mine never gets hotter then like 140 cause i only run 4s
    #8 Headbangerfacerip, May 15, 2018 at 12:53 AM
  9. Pistol87
    Jan 4, 2018
    24
    6
    Eden nc
    Arrma RC's:
    Kraton
  10. Killer Kraton
    Killer Kraton Well-Known Member
    Apr 12, 2018
    40
    13
    USA
    Arrma RC's:
    Kraton
    Temps on a furrther note.
    140 Fahrenheit on the can (inside on your rotor its hotter)and your motor" in theory" will last forever except the bearings.
    Racers push and will sacrafice the longevity of motors to push the very limits needed to be competetive.
    At 180 and hotter around 200 your rotor starts to demagnatize....over time and loose power.
    I would run those short burst races geared to temps about 170... if you want the motor to rum forever... cooler temps.
    Track racers tune by temperature literally when choosing gearing.
    So much variable you got to start somewhere and gear adjust accordingly.
    I would start with a 19 tooth with a 1600kv motor drag racing. For a guess.
  11. Killer Kraton
    Apr 12, 2018
    40
    13
    USA
    Arrma RC's:
    Kraton
    Im not a racer thi and im sure someone has some racing experience with these temps.
    My numbers are very rule of thumb... some motors can go higher but to be safe...mine are guesses
  • Welcome to Arrma Forum
  • Disclaimer
