CL-Audio
- Location
- Denver Metro Area, Colorado, USA
- Kraton 6s
- Outcast 6s
Hello fellow bashers,
I'm in the process of putting my Kraton back together after replacing all the bearings with Avids, servicing all the diffs, new oil weights, shims, new esc and receiver to go with Futaba 4PV. Here is where I'm stuck. Somewhere in this process I messed with the droop screws. Probably tightened them thinking they were loose screws. At any rate, now I have no idea what is the appropriate setting for this. Without wheels the arms are now even with the ground, don't angle up or down. I've heard that too far one way or the other cases binding on the Kraton. How in the world do i accurately set these things? I just try and eyeball it to make it even on both sides. How are you guys adjusting the droop correctly? What is correct?
Thanks all.
Thanks all.
