Hey all,
Running HW1650 max 6 with 2x 3s 6500mah plus fans etc was making my rig way too heavy for stock springs.
I have managed to find the following springs which are way heavier than stock.
Front stock Springs are 85mm 1.09N/mm(6.2lb/in)
Rear stock springs are 95mm 0.87N/mm (5.0lb/in)
New ones:-
Front 89mm 2.45N/mm (14lb/in)
Rear 101mm 2.1N/mm (12lb/in)
Probably going to get 2 more of the shorter ones for the rear as i feel the 101mm are a bit too long and put on unneeded preload on the shocks, Ordered some heavier shock oil to test but so far handles drops much better
New ones:-
