Kraton Kraton exb questions
Woodsy
New Member
Just got a kraton exb and was wondering what most ppl are running for diff fluids and do ppl change anything with shocks or tuning in the truck ? Camber caster ect....
First off --check the diff fluid----I went with 30K/300K/10K, its a known fact the diff fluid levels are LOW--Mine were as well!!
It depends if you are running LSD plates in the rear or the 12x18 (open) shims. If open then 20-30k should be fine. If running LSD x1 I would stay 10k. If using x3 then you need something super thin like shock oil 😜
Center you can go as high as you want but at least 200k. Front is similar, but 100k would be the max there for me.
