Kraton Kraton Exb rear diff revision
Markpc
New Member
For those interested, the diff in the revised exb has the LSD plates installed and in the lower action setup
The fluid was over half full. The whole diff setup had no shimming issues.
  1. Infraction
  2. Limitless
  3. Kraton 8S
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 8s
  8. Outcast 6s
  9. Talion
  10. Typhon 6s
When did you purchase ? I thought these were going to come with the spacer instead of Lsd plates ?? interesting stuff thank you for the update.
Markpc
New Member
19th December from wheelspinmodels.co.uk
I only opened up the diff today.
I was going to trust they had fixed the issue but I didn't want to find out the bad way.
BashingBrian
Get Schwifty #ArrmaAddict
UK..
  1. Infraction
  2. Mojave EXB
  3. Outcast 8s
  4. Outcast EXB
  5. Talion EXB
  6. Typhon 6s
I'm starting to think they are never going to come with that new spacer fitted, as they basically want you to pay extra for it..!! ?
MT4G3
LI, New York
I believe this was clarified back in October. A lot to sift through on this site though.
Engineer
Ohio
  1. Voltage
I don’t think they ever will. Dearden’s comments were that the second batch and Mojave EXBs would come with the LSD plates. There was no mention that they would transition the rears to be open with the spacers.
BashingBrian
UK..
  1. Infraction
  2. Mojave EXB
  3. Outcast 8s
  4. Outcast EXB
  5. Talion EXB
  6. Typhon 6s
I just ordered 2 kraton EXB’s the other day, will open and see when they arrive!
@Rcproponent
What'ya building with them ? ??
I almost bought one yesterday to create a Talion EXB, but too many other parts were out of stock..?
  1. Infraction
  2. Limitless
  3. Kraton 8S
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 8s
  8. Outcast 6s
  9. Talion
  10. Typhon 6s
@Rcproponent
Bingo! I’m making a talion EXB. Well, my rendition of it.. not exb towers, it’ll be lightweight stuff. You’ll have to stay tuned! Don’t wanna give it all away. He he. Also, I will be making another one to sell. V5 electronics and RTR out the box. We’ll see how it goes ??‍♂️ Also got a Mojave EXB to do the same thing with. Sooo, Mojave exb and kraton exb soon to the classifieds ?? brand new motors installed, diffs serviced, ready to rip. ??
@Rcproponent
Get it! You get a free hat right now ??. Plus don’t miss out on your points :)
Slow rollers are alright... (you see what I did there ) ??
MT4G3
LI, New York
Finally opened the rear diff today on an Kraton EXB I got 2 weeks ago. Fluid was very low. Only two shims under each star gear. Not 3? Added an additional 59 shim to the ring gear side. Couldn’t fit one under the pin on cup side. That side was tight.
Jimbobjr
SE PA
  1. Kraton 8S
  3. Mojave EXB
  4. Outcast 6s
  5. Talion
  6. Typhon 6s
MT4G3
LI, New York
your ziti is getting cold...:ROFLMAO:
That’s what happens when your dining room doubles as workshop.
Not going to work out with that 3rd shim I added to the ring gear side. Too crunchy when reassembled. Could it be that the diff came shimmed properly from the factory with only 2 shims per side? Every diagram I’ve seen tells me 3 per side. Maybe I’m just losing my mind...
California aka Commiefornia
  1. Kraton EXB
  2. Outcast 6s
  3. Talion
I was only able to use two per side
  1. Kraton EXB
  2. Outcast 6s
  3. Talion
Can't remember off the top of my head but I know you want the larger diameter shim at the o-rings first then the next shim to give the outdrive minimal play.
I tried 3 shims too and just felt too tight and crunchy like you said. And I was only able to fit 2 13x16 shims when installing the diff back into the diff casing @MT4G3
MT4G3
LI, New York
I took out one of the 59 shims and replaced it with a 60 Shim on the ring gear side. I believe adding .1mm even though both packages say .2. Still staying with 2 shims total
Markpc
New Member
Instructions are only good if they work. Use your own judgement on the shimming and remember not all parts are created equally or even correctly
