PshmokN’EM887
I want to upgrade my shocks on my kexb 6s beefier springs and shafts please any suggestions if you can provide direct link that would be greatly appreciated
Look under the sticky that @slick2500 postedI want to upgrade my shocks on my kexb 6s beefier springs and shafts please any suggestions if you can provide direct link that would be greatly appreciated
Shoot, I didn't even see that before Ty BroI did the M2C shaft conversion to 7mm, it was pricey but I seriously doubt I will be bending them.
Front: https://m2cracing.net/cars-and-trucks/639-m2c-3490-arrma-kraton-8s-rear-7mm-isb-shock-kit.html
Rear: https://m2cracing.net/cars-and-trucks/628-m2c-3490-arrma-kraton-8s-rear-7mm-isb-shock-kit.html
It’s for 8s can I use that in a kexb 6s?I did the M2C shaft conversion to 7mm, it was pricey but I seriously doubt I will be bending them.
I doubt thatIt’s for 8s can I use that in a kexb 6s?
Using them on both my kraton and noto with custom piston holes, smaller than stock and stock oil. Works pretty good but needs a bit more dialing in, maybe a bit havyer oil.I’m still waiting on someone to use the fireteam shocks
Ahh sorry didn't even see the 6s part sorry my reading comprehension is off tonight!!!It’s for 8s can I use that in a kexb 6s?
Can I see a pic to get an idea please and thanksUsing them on both my kraton and noto with custom piston holes, smaller than stock and stock oil. Works pretty good but needs a bit more dialing in, maybe a bit havyer oil.
How different shocks altogether?Only beefier springs that I know of are the Fireteam springs. And as far as shafts go your only option is stock.
Only the springs is different tention, the rest is kraton shocks in black color, so only change you really need is the springs, and oil/piston adjustment.Can I see a pic to get an idea please and thanks
