zizi8862
After my spektrum 150a esc burned up with a esc fire I have now changed to a max6 combo with the 1650kv motor. I have found now weight seems to be a slight issue with a lot of chassis slap during jumps. I see some people have wound the spring all the way down but I was thinking would it be better to swap out the stock springs. I also find now maybe the stock servo saver isn't strong enough as I have found turning to not be as good. I'm using a 35kg servo so I'm thinking it might be the servo savers issue.
