Kraton Kraton latest version shocks
firstchoicecp
Hey everybody,
Now I've been want g to upgrade my springs and have done the research , and seen you can upgrade to tekno or team associated 16mm springs,
So I took the lunge and bought 3 pairs of team associated sc8 16mm springs, I came to install to find out that it is so tight around the aluminum shock body and also the spring retainer doesn't fit into the spring
I measured the retainer and stick spring , they are around 20mm, so does anyone know what else would fit to replace stock springs
Thank-you
Here's what you need, I use the orange with 60w shock oil.
I use 90mm tekno orange on all 4 corners of my kraton without issue... the rear Springs could be 100 mm and work better but they have worked great. I run 70wt in front and 60wt in rear.
