Vanning
* Baja 5B differntial, FACTORY SHIMMING! Have broken rear upper arms, turnbuckles from jumping, bent shocks, diffs, still new. I have a Turtle Racing billet diff case and have not installed as there is no need for it.
* King Motor X2, AKA "Losi 5ive clone" FACTORY SHIMMING! 30.5CC ported engine with aftermarket pipe, all diffs good, no failures.
* Blackout Pro, FACTORY SHIMMING!
Have maxed out the ESC on 3S, no filures.
* .26 ported v2 engine, dual chamber pipe, 20% nitro, 5 years with the same diffs, FACTORY SHIMMING!
* GReedy .21 ported dual chamber pipe, aluminum clutch shoes, 20% nitro, FACTORY SHIMMING!
* ARRMA Talion, diff gears after more than 20 battery packs, 5S and 6S, FACTORY SHIMMING!
The gearboxes on all the AEGs have been shimmed, minus the tan one, which runs flawlessly like it is (extremely butterly smooth and accurate). In airsoft, its a must as QC is very bad from factory.
You may not need it in your applications. Only apply them if you feel it will help. Here is why I did on the Kraton. I'll repost this picture. Let's not get off topic into other applications. I posted the part # for you on the wrong post. Here it is TD310475. Not all RC's require the same attention. Each one has its ups and downs. If something isn't needed.... it simply just isn't nessasary until you find out that it is. I totally understand your point of view. Been there also. I decided to add the shims on my Kraton even though I know others do not. A few 1/8 race kits I've had come with them for some strange reason. I got RC's I've never did anything with also. My Kraton felt sloppy compared to higher end stuff.... so I fixed it. Shoot me for it !!! I'm guilty. And... I redid one recently that was getting sloppy... guess what !!!! I needed shims. It's what they are for. I see what you are saying and you are only 1/2 correct. It's not Hype... some stuff needs attention.All the above applications are with factory spec shims.
SHIMMING IS NOT NEEDED! ITS HYPE FORUM TALK!
