Chrisprice61
I took my Kraton out for the first time and sometimes it doesn't want to go in reverse. It goes forward just fine. I tried adjusting the controls but it seems like it's doing what it wants to do.
Have you time to mess around with it anymore? Hoping that it something minor you were able to adjust as well as curious as to what it was that is causing this.It may be the throttle trim. I just may been going pass that sweet spot. It seems like when I turn the knob it goes the other way.
Have you checked your esc to make sure that you're Lipo cutoff isn't set to high, meaning like around 3.8v or higher? I have mine set to shut down at 3.5v.Ok thx for answers i fiddle with throttle trim and it now looks fine, not moving by itself anymore.
The beeping still bothers me , i saw that every time it beeps, the red light on esc will go on and otherwise the same.
I can enter and change the esc setting, tried doing the throttle setup as in manual fine, but resetting the esc just wont work, i do it as in manual but only green start blinking never booth.
