Kraton Kraton rear shock lower arm mount
GBR
I just received a kraton v2 and I'm new to the hobby. I checked all the screws for tightness and discovered that the rear shock bottoms are held in with a pin but no set screw to hold them in the arm. I can remove the pin by hand. Is there something missing?
There should be a screwon the top of the arm that holds the pin in - see page 40 of the manual. Give the screw a tighten and this should fix the issue.
Thanks, Arrma is sending missing set screws.
