Gerald bobst
Suggestions on a better steering servo
Gerald did you come up with anything ?
I may have found exactly what I'm looking for . The Savox SW-1210SG Waterproof Coreless Steel Gear Digital Servo-savsw1210sg seems to be a waterproof Savox SC-1256TG . The specs are identical except it has metal gears ( which i wanted anyway ) and is slightly larger and slightly heavier.
I'm guessing it's a little heavier because of the waterproofing and steel gears over Ti and Aluminum.
Does anyone have experience with the Savox SW-1210SG . Here are the comparative specs .
Savox SW-1210SG
Dimensions(mm): 40.6x20.7x42.0
Weight(g): 71
Speed(@4.8V sec/60): .18
Torque(@4.8V oz-in): 222.2
Speed(@6.0V sec/60): .15
Torque(@6.0V oz-in): 277.7
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
IP Rating: 67
Frequency: 250-333hz
Pulse Width Frequency: 1520
Savox SC-1256TG
Dimensions(mm): 40.3x20.2x37.2
Weight(g):52.4
Gear: Titanium & Aluminum
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
The 1210sg fits perfectly in the gka mount without mods or spacers....plug and playAnyone found a proven reliable servo?
I am planning to buy the GKA Servo mount as well so i want to make sure it will fit.
The 1210sg fits perfectly in the gka mount....plug and play![]()
The 1210sg fits perfectly in the gka mount without mods or spacers....plug and play![]()
Maybe i have superpowers lol no but really i will check when back homeI double checked my PMs with Greg from GKA. He told me the Savox 1210SG will need spacers. I put it in this weekend with the stock Mount, and there is a small gap between the bottom on the mount legs, and the chassis. And the Servo is flat against the chassis pan. I'll be adding the spacers, once the mount come in.
After a lot of research i found the best option from my point of view Savox SA-1283SG with 416.6 torque at 6V and 0.13 speed, can't wait to recieve and install in my new Kraton
My servo was broken and i want also buy the 1283SG servo. Could you send me a picture?
