Kraton Shock Oil
Boostedpig
Kraton
What is the stock V3 Kraton oil weight?
I'm running a large heavy 7400mah 6s lipo so I should run heavier oil correct?
What weight oil should I buy?
Mr.Duke
NC
Outcast, Talion, Notorious
Stock is 1000cst, roughly 80wt
Personally I'd think you'd be fine with the stock 1000 and maybe move your shock mounting location to the outer most holes in the tower and/or set your preload collars on the shocks down just a bit. We're only talking 300-ish grams of additional weight as opposed to your average a 5000mah pack
Drtybird
Kraton
The oil slows the action of shock doesn't do anything for weight adjusting preload would be best
Boostedpig
Kraton
I understand that but wouldn't a heavier vehicle be able to manipulate the fluid in the shock easier so you'd want a thicker fluid to dampen the extra weight or am I wrong?
Yonic
ArrmaForum Fan
Philly, PA
Senton, Talion, Typhon, Voltage
You’re right, but the change in weight is not that massive to change the oil i think, but do check the preload with that load.
Also, depends on where you live, if it’s winter and the temps are low then you get the effect of higher weight now due to the cold, in that case i wouldnt worry about it until the summer
Drtybird
Kraton
I am having trouble with the rear kraton v3 having a lot of bounce been playing with thicker oil and position of shocks. My best change is going to emulsion setup with 1000cst. The springs are high rating and I haven't changed them but going with more preload was making it worse
The bashist
Knoxville Tennessee
BigRock, Granite, Kraton, Outcast, Talion, Typhon, BigRock 4x4
I run 50wt front and 40wt rear on my kratons. Seems to have great dampening for me this time of year in 40-50 degree weather.
Similar threads
