Yep same here the front first then the rear within 24 hrs and I'd only had the truck2 sI have been having trouble with my spiral gear. Changed the one in the front diff yesterday, took it out today now the rear one is shot.
How big were the shims you used? I could barely get one very thin washer in there.
You don't want it to be too tight because that's will cause excessive wear too. You just want to take up the excess slop with the shims. For example my front needed 3 and the rear only needed 1. The shims I use are Tekno TKR1222How big were the shims you used? I could barely get one very thin washer in there.
Oh ok I believe I achieved getn rid of the slop but I think the gears are to far gone to know if it worked until I get the replacements Arrma Is sending thanks for the help.You don't want it to be too tight because that's will cause excessive wear too. You just want to take up the excess slop with the shims. For example my front needed 3 and the rear only needed 1. The shims I use are Tekno TKR1222
My diffs required 3 shims as well, but I put 2 on one side and 1 on the other. I was trying to balance the shims and not overload one side. I also didn't want to create a super tight mesh on the ring gear. Does anyone know which method is the correct way to shim?
