I get that with my rustler if i run nimh but not with lipo....
Your batteries all good ?
Cool ! Hopefully it stays all good
This may be a longshot, but try recalibrating your ESC to controller per manual page 27 under throttle setup. I've found that turning ESC on before the controller can cause odd behaviors at any point during a run. Was having some ghost driving and loss of reverse until after recalibration. Almost wrecked Kraton 2 months ago because of it, had to manually wrestle her back under control. Hit myself in the ankle with bumper trying to shut her down....Lol.
@Rich Duperbash I'd hate to have to get in front of a 9 pound 50mph shin splitter! lol
I have always turned on the receiver first, but I can try to recalibrate for sure! I'll keep you updated!
Well, I first reset it to factory default, then I re-calibrated the receiver, then I mastered the ESC tuning. Changed the punch to 9 (not like it needs it), then I adjusted the brakes to 50%.
I ran it around with the top off doing a few short runs, and it hasn't acted up yet. I'll try it tomorrow when it gets a bit warmer.
Ran it again this morning, same issue still exists.
This is really a stretch, but have you made certain it's not something mechanical and not electrical....ie... rear drive cup grub screw off rear diff came loose? I've found they can come loose and catch the input shaft intermittently due to caked on red locker from factory. That would cause loss of forward push on harder throttle. One of my cups seemed tight, but wasn't actually locked in well, had to heat off grub screw and reseat after cleaning input shaft and cup. Couldn't discern any noise from your video. If you're feeling fairly certain your connections are all good and your LVC is set right, and ruled out mechanical drive train issues, may consider ESC swap with Arrma. Did you calibrate after ESC reset to default settings?Ran it again this morning, same issue still exists.
If you we're going front wheel drive intermittently, reverse would still appear somewhat normal, but forward propulsion would be lacking. Good to hear they'll replace your ESC though. I thought 185 ESC was from Hobby Wing, but could be wrong.@Rich Duperbash You see I wondered about that. But if it was mechanical, I'd assume it would act up in reverse also? Well, reverse isn't as fast as forward, so that may not apply... I'll definitely look at that again.
I called Arrma and they will send me a new ESC, but I'm probably going to get the HobbyWing eventually anyhow.
