Kraton Kraton Steering issues
Like that?
I give up on the video
You can only post videos from YouTube, as the forum does not allow you to import video files directly. It's easy to do, and then you just copy the link.
Ok ill do that, just to be sure we are talking about that(look at the pic) right
That's the servo saver nut that needs to be adjusted. The video shows you how to do it from the bottom of the chassis. You'll want it to sit about 5 to 7 mm off the chassis when done. It's easier to follow if you take the side guard off. To help prevent this happening in the future, put some red loctite above the nut, right before you start adjusting. Once in place. it should hold up better in the future.
And then come back and we will talk you through how to fix whatever breaks. ;)
Trying to scare the newb are we. Nothing on these rigs ever breaks. Okay, somethings might break. Awe hell, if I touch it, it's doomed?
