My tires filles with sand, so much that the front suspension balls keep unscrewing( even with super glue)They weight a ton now and the inner foam ripped and is bunchd up.Took 2 wheels apart and dumped out a pound of sand!Do i plug up the holes
Plug the rim holes for starters. Then you can heat up a metal punch and make a small hole in the actual tire somewhere between the tread. I make about a 1/8th inch hole. Water and sand will be expelled out of it. Centrifugal force will send it all out. I do this to most of my rc tires eventually. You need a hole but it's better off in the tire, rather than the rim.
Thanks for the info, i have a set of Badland Mx38 coming and have the smaller Badlands that i can use for now after I seal the rims and make a hole in the tire!I'm going to have to try this as my TC's are WAY out of balance
I would be checking the glue on your tires if your filling them with sand they are probably unglued in a few places... keep them glued up, if your gonna plug the holes in the rims use shoe goo or silicone so you can take it off if ya want to. if the balls are coming unscrewed you have a serious balance issue get new tires and wheels and try again. keep an eye on them if they show any small spots coming unglued get tire glue on it right away. Running 6s holding it pinned and letting tires balloon is gonna blow them off the rims.My tires filles with sand, so much that the front suspension balls keep unscrewing( even with super glue)They weight a ton now and the inner foam ripped and is bunchd up.Took 2 wheels apart and dumped out a pound of sand!Do i plug up the holes
Tire glue was fine, the 1/2 pound sand caused a major inbalance on just 4s for each tire.I would be checking the glue on your tires if your filling them with sand they are probably unglued in a few places... keep them glued up, if your gonna plug the holes in the rims use shoe goo or silicone so you can take it off if ya want to. if the balls are coming unscrewed you have a serious balance issue get new tires and wheels and try again. keep an eye on them if they show any small spots coming unglued get tire glue on it right away. Running 6s holding it pinned and letting tires balloon is gonna blow them off the rims.
Sometimes when you purchase non mounted rims and tires from Pro-Line....you will notice that the holes are not open in the rims. They did this so you can make that decision.....On pre mounted rims and tires, I notice that the rim is mostly drilled and the tires have no holes. I have talked to Pro-Line and they recommend putting a hole or 2 in the tire. Keep the rim plugged up. I like burning holes through them.....it smells fantastic.
What everyone else says... soak tires in acetone to remove the glue. Plug holes in the wheel and vent the tires. Many videos on youtube
I have always plugged both holes to keep water out. Whats this about a hole in the tread? that will vent the tire I understand but won't it also let the water in and ruin the foam? If its something I need to do - Pls tell me - don't want to ruin another set....Ive ruined a lot of sets - Im kinda good at it...
Morning,
So I close the holes in the rims and make a new hole with a hot metal punch into the tire ?
Do you have a pic for me, where to make the new hole ?
It looks like the tires and rims off the new Arrma Outcast will be a great tire on the Kraton. It looks like Arrma came up with their own Badlands. They are called Backflips. It looks like they will please the people who feel Badlands are a little small. I really, really like the new Outcast but I'm unsure about the short wheel base. I think I'll get one anyway.
