Kraton Kraton turnbuckle
Reaper007
Busted my ball cup on my kratons turnbuckle..does anyone sell aluminium ball cups that will fit the kratons turnbuckle..I'm trying not to go back to plastic if i don't have too..
TooTall
4x4-Mega, Granite, Infraction, Kraton 8S, Kraton 6s, Mojave, Nero, Notorious, Talion, Typhon 6s
When you say turnbuckle ball cup, are you talking pillow ball on the front hub?
Or are you saying the eyelet on the end of the straight link in the rear?
TT
Reaper007
The ball cups that screw onto the end of the turnbuckle..or tie rod..
TooTall
Steering linkage in front or suspension in the rear?
if it is front steering, did it break or just pop off, as it is known issue to have pop off, you can put a small oring on the ball joint end or use a c-clip, there are a couple posts on here about that.
Either way i would recommend staying plastic, as aluminum would just transfer that energy further inward and break other things.
TT
Reaper007
Thanks..that does make sense..the ball cup eyelet tore out..so i wanted something stronger..will do the o-ring and clip so it won't pop out..
