Granite Kraton tyres on the Arrma Granite
lynnwilliam
I want to put Arrma Kraton tyres (200mm) diameter.
on my Arrma Granite which has (120mm) diameter types.
I'm willing to cut into my chassis so the bigger wheels can turn correctly.
But I would also need hex extensions, can someone recommend some ?
SrC
RC is a lifestyle choice
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
200mm is way too big IMHO. Cutting the chassis..????????????? Not a great idea. Are you trying to make a 8srig out of your Granite????
I imagine you are talking about the Kraton Copperhead 2 wheels??? 200mm will make it run hotter as well. The final drive will be taller with the larger roll out of these Kraton tires. Others may chime in hopefully.
