daredevils
Does anyone knows if the 4mm shocks assembly from v3 kraton direct fit a v2 kraton?
Yes, but you will need a V3 stand-off for the top. I have a V2 and V3 Kraton.Does anyone knows if the 4mm shocks assembly from v3 kraton direct fit a v2 kraton?
Here you go. Mounts to the shock tower and sits in between the shock cap hole.what is a V3 stand-off? do you have a picture?
No problem. AttachedThanks man, do you have a part number by any chance?
You can do it that way too, but I prefer to change out the standoff and run the shock cap protectors also.is that a better way to do it? check out this guy's video on youtube....
You’re welcome anytime ?. It isn’t a huge difference between both but the V3 takes abuse slightly better due to some of the beefed up components.hey man , thank you soo much for your help! did you notice a difference with the v3?
