Bluebird Bls 42a,$75 dollars delivered.Will let you know how it works out!Wow, that is a good price for those specs! I wonder if it's any good? What is the model number for that servo?
If only such a servo existed!Oh, my bad I misread. I thought u said the servo was 9.50, sillly me lol
Yea, for sure. I'm running the Savox SA-1231SG. $69 and 444oz-in torque at 6v which is what the stock BEC puts out.If only such a servo existed!
Bluebird has a helical cut gear servo also in the standard size that does 798-in at 8.4 ,speed .09,amazing amount of torqueYea, for sure. I'm running the Savox SA-1231SG. $69 and 444oz-in torque at 6v which is what the stock BEC puts out.
Which one,the Bls42a?I just put this servo in my kraton and had installed it in my Nero a couple months ago. Love it plenty fast and tons of torque
No, savox 1231sg 444oz/inWhich one,the Bls42a?
Probably not,the specs don't give it's centering ability and it's torque is barely higher than stock.Maybe someone has already tryed it?Dos anybody know this one?
https://www.wirelessmadness.com/power-hd-lf20-metal-geared-20kg-digital-servo-hdlf-20mg?keyword=power hd
Will this servo be a reel upgrade ?
Does the stock servo in the Kraton have metal or plastic gears mine lasted about 4 batteries then stripped! What do you recommend?Yea, for sure. I'm running the Savox SA-1231SG. $69 and 444oz-in torque at 6v which is what the stock BEC puts out.
The stock servo is metal geared, but it is rather weak for an 8th scale truggy. I can recommend the savox servo I mentioned, big upgrade over the stock. Savox sells a great servo, I have yet to have one fail on me.Does the stock servo in the Kraton have metal or plastic gears mine lasted about 4 batteries then stripped! What do you recommend?
I went with the Diy servo mount.At first i had the servo on top so i had to use a spacer to make the linkage level,that caused the plastic to squirm, so i remounted the servo under the plate and it came out level with no spacers.I also installed bearings in the steering post and that helped servo speed!The stock servo is metal geared, but it is rather weak for an 8th scale truggy. I can recommend the savox servo I mentioned, big upgrade over the stock. Savox sells a great servo, I have yet to have one fail on me.
It is a bit taller, so you will have to add shims to install it. Or replace your servo mount with one of the aluminum ones available. Another great upgrade, as the stock mount flexes quite a bit.
I did the DIY also. The Savox servo I'm using is taller than stock though, had go go on top of the mount.I went with the Diy servo mount.At first i had the servo on top so i had to use a spacer to make the linkage level,that caused the plastic to squirm, so i remounted the servo under the plate and it came out level with no spacers.I also installed bearings in the steering post and that helped servo speed!
I'm running this servo in my Kraton
http://www.banggood.com/JX-PDI-6221...tal-Coreless-Servo-For-RC-Model-p-973947.html
$13 works great,, I have yet to kill one. I use them in lots of 1/8 trucks
I was wondering about those servo's, how's the centering as the deadband is 2us?
Got my Bl42a installed.Everything works great. I have Savox 1230, & 1231 servos also. But I like testing bargain parts. I bought 4 of these, and haven't had a failure. I've use them in 7.2v as well, with no glitching.
