btosic
Kraton and Typhon, bought the same day. On every bashing driven together, at total of 100+ packs per car, same conditions(snow, mud, dry) mostly away from asphalt.
Kraton and Typhon have: alu braces, alu servo mount, alu central diff mount, Yeah Racin motor cooler with twin Tornado fans, punch set to 7.Kraton was on 14t pinion(now 22 with 1480KV motor), typhon on 20t pinion
Both cars have stock diff oil weight, both are regulary mainteind by advanced level wrencher and RC hobbyst.
Kraton is on Max6 and Hobbystar 4092 1480KV for about 2 weeks, so two weeks are out of comparison.
I haven't count regular servicing(tires, gaskets, o-rings, screws and bearings).
Kraton:
-Wing mount problem, solved with proper shims
-Problem with losing wheels, solved
-Peoblem with upper shock mount bolt
-Problem with stock shock towers(bending)
-Striped rear diff pinion
-Damged rear and front diff spur
-Pillow ball screws lost(solved with tape, works great, easy for removing)
-Servo saver keeps coming lose
My fault:
-Broken Arms
-Light damage on body
Typhon:
-Damaged body from ballooning tires.
Period, that is all.
Typhon is my overall hobby class 1/8 el. RC champion. The car is so well constructed, weight to structural strength is very good, so it just keeps going. No problems with diffs, inside, and on spur or pinion, no bending, everything is short and stiff.
I won't say a single bad word about Kraton, I love it, it is so nice, it has that fun factor, it is well built, but Typhon is a better car. If not yet, give a Typhon 6S a chance, I have a feeling that Typhon 6S is one of a few cars that would be near 100% of our expectations!
Have a good bashing my friends!
Kraton:
My fault:
-Broken Arms
Typhon:
