I don't have a Kraton but I use the stock radio in my Outcast. My SCX10-II and my Typhon also have the same radio.what radio and receiver do you use in the kraton
I think this is an esc issue, my reverse with the stock radio wouldn't work all the time as well, I swapped in a different radio and the reverse still acted up. I swapped out the BLX185 for a Max8 and the reverse works normal with the stock radio.I m using the fly sky and there receiver and the reverse don t work all the time for some reason
I have a DX5C as well, my only gripe is the scroll wheel I just don't like the feel of it as you are scrolling and clicking through the menus, and it is a bit too easy to click the wheel while trying to scroll.I use the spektrum dx5c with mine, with the srs6000 reciever. I really like it.
I've looked at the RadioLink TX often. I like the low cost of $15 RX and wish others would have a better price for receivers. The gyro in the cheaper rx is a bonus but probably wouldn't need unless I changed out my single 2wd truck.My RadioLink is working pretty good. Haven't got to check distance yet, but I do like the built in gyro. Have it in my Typhon 3S, and 2 of my Red Cats. Will be installing receivers in my Kraton and Nortorious today. RadioLink has 10 model memory. Not bad for $80, and receivers for $15
How much range do you get with that receiver? That is the internal antenna model right?Futaba 4PV and R314SB-E have been flawless.
