Talion Larger rear wheels
mostin
New Member
Has anyone tried running larger rear wheels on a talion or smaller fronts on a kraton? E.g. take the fronts off a talion and swap them with the fronts from a kraton. This would mess with the diff values a bit. Effectively giving you potentially more push from the rear vs a faster turning smaller front wheel. This is on my talion 6s running 6s 100c batts. I have so much power that all wheels are spinning on all surfaces anyway. So its more a matter of grip over what power is being sent to front and rear. Any thoughts on this. ? Rear tires are 150mm backflips. Fronts are standard 105mm talion katar.
That was my first thought. But 6s and 100c I have all four wheels spinning out on any surface. If they are all spinning then the message to the diff is no matter. If I had full traction all wheels then yes I would say trouble. I’ve ran about 3 runs so far without trouble. This is the battery setup. A bit of squeeze with the hard backs but they go in tight.
Here’s what she looks like.
How does it handle? Running stock center diff fluid? I have Katars on my K6s but I have a spare pair of Minokawas, might just give it a try for sh**s and giggles :D
