Summitp
I have found the threads here, and the F@#$book threads around larger tires for a mojave to be frustrating, and lacking in detail around what actually works, and how to get it to work. So my goal here is to show in detail how to make the backflip 4s wheels and tires work with a mojave, mine is an exb.
This change will net significant improvements in handling. The truck exhibits fewer rollovers, and is more stable in fast rough conditions. It is also more adjustable in the air thanks the the larger rotating mass.
First off, the backflip 4s wheels and tires are significantly larger than stock. So you will need to regear. I am running a mamba monster 2 2200kv system. I regeared with a 13t pinion and motor temp after rompin a full 6s pack were 185f, but it's chilly out.
Second, you will need to trim the body significantly to get them to not rub under compression. You will also need to trim about 3/4" off either end of the front bumper so they don't rub when turning.
Third, the hex depth on the backflip wheels is approximately 1.5mm deeper than the stock wheels, and will rub against the hub carriers with the stock hub hexes. You can run some alternate hex, or, what I did, is use a small spacer. I found some copper crush washers commonly used in oil filters for bmws (and many other uses) and they were a perfect fit. This gave the clearance needed for the wheel to clear the hub carriers.
Fourth, I do recommend bumping up the thickness of the shock oil on all 4 corners. I am using 710cst losi oil. The suspension is still pretty soft, but better control over the larger wheels and tires is needed over stock, and the thicker oil gives you that.
So, here you, some pics, and a running video.
Youtube video... Thanks to my 8yo cameraman.
