Leaking diffs and Green slime
-Dusty-
Canada
Kraton 6s, Outcast 6s
Hello. I been having a little trouble with these diffs leaking by the o-ring. I take them apart and try re seating the o-ring and sometimes its ok, but I find that, for me, that is where the diff will leak. I do have shims behind the sun gears, which I think helps a little but on my outcast it still leaks.
Will green slime help with that, I have read good things about it and thinking I could try it out. I couldn't find the Team Associated brand, but I did order some Losi green slime (should work)
Does anyone have any other tips that might help in this situation. Probably the main problem I am having with my RC's right now.
Thanks!
-Dusty-
Canada
are the stock o-rings decent? or should I look at something else?
Krathead
Arizona
Make sure you use a good o-ring grease when replacing. It can make all the difference in the world.
