- Winnipeg
- BigRock
- Mojave EXB
- Senton 3s
- Typhon Mega
- Vorteks
Last year I got back into RCs after over a decade. Prior, I owned an HPI Savage with a nitro engine. I found nitro engines to be a PITA to run and sold the RC. I bought an Arrma Typhon MEGA and got the bug after seeing how fast and fun electric RCs are, albeit rather quiet compared to the nitro RCs. I picked up a Big Rock and a Vorteks over time, and now I've made the step into the larger 1/7th scale with the very hyped-up Arrma Mojave. With thanks to the community here and a few groups on Facebook, I made the choice to get the EXB and buy my own electronics.
From owning the Vorteks, I really liked the ecosystem from Spektrum. Yes, I had trouble with my Firma 100a ESC and an LVC issue which I blame for causing one of my Spektrum 3s batteries to have a bad cell. (11 ohms on one cell after 4 months of owning it.) However, I learned how to fix that problem and potentially avoid the issue with other products. I'll explain that later.
I learned that getting better gear and not pushing it to the limit can help with longevity. And so, I went with the Spektrum Firma 160a ESC and 1250 kV motor to run on 6s, even though it's 8s capable.
The servo is a Savox SW-1210SG, chosen as a suggestion by my local hobby shop. I later learned the Firma 160a does not have BEC for 7.4v. Only 6.0 and 8.4, even after a firmware update. So my Savox isn't at its full potential, but I'm having zero issues with it after 5 runs. In fact, I found it to be far faster and stronger than the Amazon 25kg deal I have for my Vorteks.
I went with a 23t pinion to run with. My LHS didn't have a 22t in stock which seemed to be a popular choice, but the 23t is doing well for me. No heat issues. Certainly enough torque, and fast. See the one issue in the picture? This is when I put the pinion on thinking it was aimed the same way as my Vorteks and Big Rock. Oops. Thankfully the dab of Blue Locktite didn't set yet and was easy enough to remove and swap around properly.
The Firma 160a ESC took me a bit to figure out how to mount in my Mojave. This thing is huge compared to the 100a ESCs in my 3s Arrmas! I've seen people online would cut off the side tabs to make it fit, or put a huge zip tie right over the whole thing. What I did was put the double-sided tape onto the mounting plate that comes with the Mojave EXB and squished in the ESC slowly and let it sit where it wanted to sit. Then I unscrewed the mounting plate and removed the ESC and plate together. Once I had it in hand, I could see two of the mounting tabs on the ESC were rather close to holes in the mounting plate. So I just took two zip ties and tied two points together. I never took pics while I was doing this, sorry, but here are pics once it's all in place.
As you can see from the dirt, this has been bashed about 5 times, 25-30 minutes per time, over very rough terrain, and that ESC has not budged. The double-sided tape and those zip ties are holding it very well. Plus it's really snug in there, so little room to wiggle.
From owning the Vorteks and having issues with my Firma 100 ESC, I've learned the importance to pick up the Spektrum Program card and update the firmware.
Just like my Firma 100a, 130a, and now my 160a, there was an update waiting to be loaded. I, unfortunately, cannot tell you the difference between before and after this update on my 160a because I did it before I even ran the RC. But with my 100a and 130a, new features such as BEC settings did appear that weren't there, as well as different defaults, such as timing.
I encourage all to look into updating the firmware on their electronics. I believe you can do with this Hobby Wing and maybe Castle as well.
To protect what I can, I've added foam to the bumpers and mounting points which have been suggested by nearly everyone I see with a Mojave and added Gorilla Tape to the inside of the Mojave body. (I've done the drywall tape and Shoo Goo on my Vorteks. That is far too tedious and no one seems to talk about the lingering smell!)
I ordered Scorched fenders last night and looking forward to putting those on and hopefully reducing the amount of debris I find in my Mojave after every run. The thing is a lawnmower in the grass and a Hoover on gravel.
