- Thread starter
- #21
So it would be fine to charge it at 6amps? Oh AMD thank you everyone for helping.
A charge rate of 1C would be 6.5 amps. 2C would be 13 amps.
I've read that your batteries last longer if you charge at 1C. Not run time, useful life.Unless 6 amps is a limit on your charger, then why not charge at a higher rate? 6 amps (just under 1c) is only going to take you a lot longer
[/QUOTE
Yeah, that's all I have. It took awhile to charge it last night. About 2 hours. UGH!! Lol
I'm guessing that you have a 50 watt charger and you set the amps to 6 but it probably actually charged it around 3 amps as you had hit your 50 watt maximum.
save up and buy a bigger charger would be my recommendation
Ok. I'll have to do that. This one works, but takes to Long. Will be getting another one soonsave up and buy a bigger charger would be my recommendation
Remember to charge a 5000mah 6s lipo at 1c you need at the very least a 150 watt charger if going with an AC charger (if using a DC charger you can get away with 126 watts if you run at least a 150 watt psu). 5000mah x 25.2v = 126,000 milliwatts or 126 watts and then we need to add in 20%, because every electronic device on the planet is about 80% efficient iirc even high end computer server power supplies at best are someplace around 90% efficient so you will always loose some of the power to heat, and that gives us 151.2 watts. Also this allows you some headroom so you are not running your charger at 100% all the time.Ok. I'll have to do that. This one works, but takes to Long. Will be getting another one soon
