ParkRacing
Well thanks so much for doing that and sending the results! Your Input is a huge help!I ran my Kraton today on 5S, 1480KV Leopard, 20 Tooth pinion. It hits 43 mph. I'll get right to the point.....In a Kraton, this motor is a solid 6S motor.....no good for 5S. I'm positive that it will not make this truck shine on 5S. It's too low of a KV to get the proper RPM and the right gear ratio. I feel it will never be in a sweet spot unless it was geared with a smaller pinion. If you got all 5S packs Parkracing..just get the 1780 kv. It should be bad ass on it. You probably will not need a fan
6S will put it where you want. 5S...I wouldn't want it. That's a 6S run there...after 25 mins I'm still going without hitting the lipo cut off. I would normally hit lipo cut off on 5S at 18mins on the stock motor. But that's different with everyone.
