- Bozeangeles
- BigRock 4x4
- Kraton EXB
- Kraton 4s
- Notorious
- Senton 3s
- Typhon 6s
- Typhon 3s
Congratulations!
I wonder if the Infraction rear shaft bearing support brace would be a fit for your idler bearing? Might hold up longer?Thanks everyone!
So far things are going well and we are getting a decent amount of sleep.
I was even able to get in a little garage time in the past few days. Yesterday I drilled the hole in the aluminum carrier and 2 holes in the chassis to mount the rear idler/tensioner. Hopefully the 3d printed block holds up for a while. The idler has ball bearings and I will be oiling them each day I run the car for extra insurance.
Yesterday the EXB servo mount came in the mail. This means the car is an extreme bash edition now right?!
Yeah possibly, I figured I would just buy a chunk of aluminum and make one if needed. It has a 5mm steel rod inside that the idler is sitting on so the plastic part is only holding the one side. I expect it should be fine.I wonder if the Infraction rear shaft bearing support brace would be a fit for your idler bearing? Might hold up longer?
Have you also thought about making a (RC) support vehicle? With a 15deg steering cap it will take ages to do a U-turn. If have your RC crane/forklift/tow vehicle you can drive it up there and assist
I figured. I was just looking for an excuse why you would need a support vehicleThe airport runways are extremely wide so I should be ok
With my 1/8 and 1/7 streamliner bodies the steering was limited and still were able to do u-turns without issues. It always surprised people.
He just needs a kickstand that retracts from the center of the chassisHave you also thought about making a (RC) support vehicle? With a 15deg steering cap it will take ages to do a U-turn. If have your RC crane/forklift/tow vehicle you can drive it up there and assist
Yessssssssssss way better!Gettin' closer, I'm guessing the aluminum was a lot easier to drill than the steel bars.
The vinyl ocean was the first thing that caught my eyeMy wife says my vinyl ocean view is nerdy, but I like it. Very relaxing
In case you really like this one... (I wish it was a bit larger, but it was very cheap so I can't complain)The vinyl ocean was the first thing that caught my eye
I've been thinking about something similar, you might have just convinced me i really should
My wife keeps pushing that we need to go to the ocean this summer. This is not helping me with saying no
This summer, post-COVID, any vacation spot (including routes and terminals) is going to be a monumental clusterfack. Resist the urge!My wife keeps pushing that we need to go to the ocean this summer. This is not helping me with saying no
I don't think we can afford it...
Yeah I bet it will be crowded / busy.This summer, post-COVID, any vacation spot (including routes and terminals) is going to be a monumental clusterfack. Resist the urge!
