I think you would need at least a 70mm fan but most likely a 90mm to hit the kind of speeds you want. I fly with 64mm fans in pretty light weight aircraft and just don't think they would have the amount of thrust your needing. I could be wrong but would be surprised.
The Chaparral fans were powered by a snowmobile engine.Well that makes a lot more sense! I guess that is why I am still learning.
And the Brabham was Designed by Gordon Murry
Both cars were banned from their respective series CanAm and F1. Both cars drew air from under the car to suck them down closer to the ground. If you look both cars have skirts to seal the bottom off to the road . All in the name of more downforce. Both were pioneers in Ground effects .
