- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
- Thread starter
- #201
I was on it tho!The diameter is so big it make the length look short..!!
( and before anybody else... That's what she said ?? )
Color is off a bit, but contour is spot on ????More than anything I was just messing around. I don't believe I'll spend much time running this car as a buggy, but it was fun to design a nose for the car. This keeps the car within the ROSSA rules for open wheel buggy while adding some aero improvements!
It does still need some additional work as it needs more room around the upper a-arms for suspension travel.
It is very possible I went too big, but the KV is very low....Are you sure that pinion is big enough..!!! ???
Body came out of the mold so nice and clean with the PVA spray.
I have a few spots where air bubbles need to be patched up but overall it turned out great!
After patching those spots I'll put on clear coat and it will be soooooooooooooo pretty you might leave your wife.
There is a 2 month wait time. My friend who pre-purchased 2 bodies (which funded the materials/process) wanted a 2 month head start to beat some records before others get their hands on this body
It's really just not fair how pretty that is...Pre-view of how it might look with clear coat on. Just finished some sanding a few spots that I touched up, and rinsed off with the hose.
The spots I sanded on hold the water still....
What’s the thing weigh?Pre-view of how it might look with clear coat on. Just finished some sanding a few spots that I touched up, and rinsed off with the hose.
