- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
- Thread starter
- #21
They are 90 degree aluminum servo mounts.What are you using for body posts?
Very cool! I’ve been wanting to get a 3D printer at some point. What software are you using to create the prints?The print for the gear cover turned out ok. Much more bulky than it needs to be but I'm not short on open space with this car
Also printed a simple 90 degree bracket to hang the RX off the side of the center brace.
Next I'll print some sort of fan mount for the motor.
I like Fusion 360 for the drawing. Free for hobiests and lots of good tutorials on YT to help you learn it. Then Cura slices the drawing creating the g code for the printer.Very cool! I’ve been wanting to get a 3D printer at some point. What software are you using to create the prints?
Very impressive! I might be in line for one of those when they are hot off the press ??Had a bit too much height above the tires and the shape was just too square and looked bad to me.
Refined and smoothed some edges on the design.
Also removed some height above the tires.
New design is considerably more rounded and removed about 9mm of height. Also added more height in the center section as it opens more options for body mounting. Getting really close to being ready for print:
Easy to raise body posts. Harder to cut them down. ????I think I am going to start with something a little more simple that is going to fit more cars. I suspect that center section would limit the fitment down significantly.
CorrectLooks very cool so far! Are you using the CF piece instead of the chassis braces?
You’re doubling the chassis?The 4tec 2.0 project is a bit complicated. I'm working on a stretched chassis build and it will be running a monster tp4070 and 8s.
This is just a rough draft for visualizing the space...
At least enough to accommodate both batteries and a big motor. A second chassis is coming in next week and I'll make the first cut. $12 and free shipping. Very similar to Typhon chassis pricesYou’re doubling the chassis?
Could you have not made it any longer...???
Look forward to seeing how this goes, it's not Arrma based though is it.??..??
