tiarc
- Typhon 3s
Hello Arrma fam,
I recently pick up a typon 3s and want to say thanks to this forum for the tips/tricks. I will most likely stick with the 3s vs the 6s as Im a fan its light weight, plus the speed is quite good relative to its cost. I have upgraded to pro-line powerstroke shocks and that comes to my first thanks; tips on how to bleed shocks. There was a lot of different opinions which was hard to reference at first, but it was the choice of options that eventually help the most. I gravitated to the dead shock, ie a shock with little to no rebound. This tip was key, as I was rather skeptical of the proline "value" relative to its cost. My takeaway; its the dual rate springs that differentiate these shocks and the dead rebound is key to ensure the helper spring can do its job. The net, improve handling which led to better driving dynamics. Less flips, better slide recovery and drift control. Its a noticeable difference over stock and I now want to upgrade the servo to improve steering response, something I did not realize I wanted until I added the shocks. Im less convince that dual rate springs are ideal for big air, so if that your thing I would do some homework. Thanks all
