soulreaper_msd1
+1Also consider running less power until you have the car dialed and understand how it drives.
Limitless V1 or V2?ya i just pretty much totaled my infraction 6s few days ago. it found a cub at about 80mph.
gonna have to put a bigger motor mount in limitless for castle 2028 sensored motor 1700kv. any suggestions?
v2Limitless V1 or V2?
https://www.arrma-rc.com/de/product/sliding-motor-mount-plate-56-series-red/ARA320722.htmlya i just pretty much totaled my infraction 6s few days ago. it found a cub at about 80mph.
thanksIf Raz can get the perfect pass carbon drive shafts back in stock on Amazon that would be a good next upgrade.
Beyond that they are pretty great rigs out of the box.
How did you fit CNHL 9500 in the V1 battery tray?For batteries. I'm running CNHL 4S 9500
i got that mount .. works great.. thankshttps://www.arrma-rc.com/de/product/sliding-motor-mount-plate-56-series-red/ARA320722.html
You can use stock limitless v2 mount with that plate and the castle 2028. I didn't realize the castle 2028 could fit in a limitless v2 though.
They barely fit. I put them in with the leads to the rear and the wires on the Driver's right. That is the only way I've gotten them to fit all the way in. It helps if you completely undo all the straps.How did you fit CNHL 9500 in the V1 battery tray?
I’ll give it a shot. Thanks.They barely fit. I put them in with the leads to the rear and the wires on the Driver's right. That is the only way I've gotten them to fit all the way in. It helps if you completely undo all the straps.
