Big_House3rd
New Member
Gearing question...can the Felony 15t input gear fit in the v1 Limitless with the 43t ring gear?
Hey so in the limitless we can use GP5 in the Front and the GP6 in the back?? Please help thanksNo.
GP5 15T input will not work with a Lim. 43 ring gear. There is only one LIm. The first release. It hasn't been revised. There is no v2 Lim. FWIW.
43T ring mates to the 10T input gear and are the standard. Lim gears. Front and rear have the same ratio. Identical
Fel. GP6 and GP5 gears have a different pitch, tooth count and size tooth profile. And each input gear needs it appropriate ring Gear. None are interchangeable. GP6(Rear) stays with GP6, (14/45)
GP5( front) goes with GP5 (15/42) The difference front to rear on the Fel. is because of the larger rear diameter wheels. Front to rear gear ratio had to be accounted for due to the larger rear tire roll out.
Welcome to AF.
No u need to stick with one for f. And r. Unless u use 2 different size tiresHey so in the limitless we can use GP5 in the Front and the GP6 in the back?? Please help thanks
Thanks so much buddy!! But can I use the 14t GP6 gear with 43t diffNo u need to stick with one for f. And r. Unless u use 2 different size tires
Read my post again. There is much info there. Maybe you got confused.Hey so in the limitless we can use GP5 in the Front and the GP6 in the back?? Please help thanks
Thanks that really help me out!!! Just one more question is there any difference in using the GP5 in front and back overstock??Read my post again. There is much info there. Maybe you got confused.
The answer is NO. GP6 in the rear will need the 53/107 Hoons (taller) And they don't fit the Lim. at the rear. Use GP5 front and rear. They will fit the standard Fr/Rr bulkheads. And just use the smaller 42/100mm Hoons Fr and Rr. V2 Infraction is this way out the box.
Hope that helps. .
