Limitless Limitless on stock gearing - Calculating top speed - What is the transmission ratio?
The stock limitless pinion/spur ratio is 1.26 (rounded up).
Thats a 27t pinion on a 34t spool.
What's the transmission ratio then? I'm trying to use RC Car GearCalc to see theoretically top speed.
It's not 127 on 2s.... Is it?
Based on a limitless stock pinion and spool with stock tires.
Internal gear ratio -> 43 / 13 = 3.307
Spur-pinion ratio -> 34 / 27 = 1.259
Final drive ratio -> 1.259 * 3.307 = 4.16
Tire circumference -> 100 * 3.14 = 314
Tire rollout -> 314 / 4.16 = 75.48
RPM -> ( 2050 * 25.2 ) / 1.259 = 41,032
I have no idea how to calculate theoretical speed (haven't gotten there yet). This is based on 6S.
That is the calculator I use.
For that spot that says transmission ratio put in 3.3
To get more accurate results don't put in 25.2 volts because in a speed run you have significant voltage sag. I'd probably input 19V as a ball park and that should make the calculated speeds pretty close.
Got it. It says 104MPH at 16.8V which I know it will never be, but just wanted the theoretical!
Sorry I'm being daft - what information did you use and what was the speed?
You just need to fill in the boxes with all the info relating to your RC.
The Limitless has a 13T diff pinion and a 43T diff spur, ...everything else will depend on your set up. E.g Motor Kv and tyre diameter etc.
Hope that helps.
