Leejax01
- Kraton 6s
Hey guys, I’ve been having an issue that’s been puzzling. It’s on a drag Limitless. I was running an XLX & a 6S system. Connectors are QS8 & 8 gauge wire where applicable. The car started to cut out on the hit with any battery other than a cheaper Lectron 6S pack. Thought it was the esc, so bought a newer XLX2.
Fast forward and I bought a 6S SMC 150C battery and it cuts out it again. Every hit this time like click work. Thinking maybe the motor or connectors, I bought a new motor, replaced the 8 gauge wire with new wire and new 8mm Castle connectors. Tried again and same thing. So at this point it’s a new esc, motor and 8 gauge wiring and even new QS8 connectors. It would cut out other than with my cheaper Lectron battery.
Last night we tried the car with the Lectron 6S battery and every hit it would cut out. Not matter starting power, punch settings, low voltage cut off is disabled. It shows 25.2V with .78V max ripple. At this point, there’s 2 different esc’s, 2 different motors, new wiring, countless esc & calibrations in different orientations that it’s getting ridiculous. Nothing is overpowered as it’s 6S on an 8S esc. Any help or direction is appreciated.
