dk10438
- Limitless
Awesome build!
@RedondoBeachRC is a stand up guy and I enjoy running with him on weekends.
GL on finishing this bad boy!
If not , sbus port can used in parallel so if you have a splitter, you can run rhe CC, gyro output and other telemetry using the sbus port on the receiver. I use the futaba sbus (which is 3:1)hub and i connect rhe CC tele, gyro and futaba temp sensor to the sbus.
The hub itself isn’t necessary and I’ve actually used multiple splitters to achieve the same result. You might want to consider a futaba servo which would allow you to use SR mode as well as the ability to program the servo.
Not sure if you ever got an answer to this but I have similar builds.View attachment 138471
So I know I’m jet lagged (got home after 1:00am) trying to figure out the best way to connect everything.
I have a Futaba 7PXR with R334SBS-E receiver
Futaba GYC441 gyro.
Question is: I would like to use the Telemetry feature, everything I have read confuses me more! Do I use S-BUS2 for the gyro, or Castle Telemetry Link?
