Limitless Limitless to infraction
Rad369
  1. Outcast 4s
Thanks to you guys already building infractions I will build my own Infraction will be slow going 8s ain't cheap
Still got to sell top and all the rest of the parts Before I can start buying stuff
Got some of the necessary parts removed
Ordered top yesterday came in 2 day other parts from Same state will be here tomorrow hopefully
Body post and Roll cage thats it for the body just need esc and radio
Roll cage install now to figure out hobby Max 5 or castle
Thanks but I got it all assembled Just need a speed controller and radio
I was asking you a question, was that all it took to make the Limitless an infraction? ( specifically on the front end)
I want to make a Limitless GT car
You need those from pieces and the rear body mount (which comes with the front mount) but yeah that's it to mount the body. You could technically skip the foam part it's just there to give the front of the body a little support so it doesn't completely cave in during a crash.
Finally decided and purchased esc today And I got this one decided I didn't need a Bigger esc probably be a bigger headache hitting something at over 100 mph
Did not realize it was going to be that f##$ing big Houston we might have a problem
I’m guessing the limitless was designed with the MAX6+4985 combo and it’s rebadged arrma version in mind. The stock motor space is just about 90mm long, and I am reasonably sure even if there was space lengthwise that motor you got wont fit the factory motor mount.
The motor will fit just gotta squeeze it in I just hope I can keep using the motor mount that's in it
85mm is supposed to be the last length can that fits in the limitless/infraction. 87mm is cutting it close but might get away with it. The other option you have if it doesn't fit is to turn the motor mount around 180 degrees but that means losing a battery tray and probably needing to ditch the esc mounting plate since it will sit very close to the pinion gear once mounted. I learned all this when I tried to fit a 4092 motor in the stock location and it didn't fit so then tried different mounting configurations until I gave up and switched to a 4585 motor can instead.
Took the spool out added a center diff Looking to do more than a couple speed runs before i have to shut it down
