I was asking you a question, was that all it took to make the Limitless an infraction? ( specifically on the front end)Thanks but I got it all assembled Just need a speed controller and radio
You need those from pieces and the rear body mount (which comes with the front mount) but yeah that's it to mount the body. You could technically skip the foam part it's just there to give the front of the body a little support so it doesn't completely cave in during a crash.I was asking you a question, was that all it took to make the Limitless an infraction? ( specifically on the front end)
I want to make a Limitless GT car
I’m guessing the limitless was designed with the MAX6+4985 combo and it’s rebadged arrma version in mind. The stock motor space is just about 90mm long, and I am reasonably sure even if there was space lengthwise that motor you got wont fit the factory motor mount.Did not realize it was going to be that f##$ing big Houston we might have a problem
