Limitless Limitless V2 center diff bearing cover options
332_RC
Backyard Basher-Parts Swapper
Hospitality Award
Build Thread Contributor RC Showcase: 8
USA, Georgia
  1. Gorgon
  2. Infraction
  3. Kraton 6s
  4. Notorious
  5. Outcast 6s
  6. Senton 3s
  7. Talion EXB
  8. Infraction 4x4
Anyone know of a Limitless V2 center diff bearing cover that the sides are aluminum? Other than this Amazon/eBay special? This one has aluminum sides & a carbon fiber top. Don't really care for the CF top. Rather have aluminum. The stock Arrma one is metal but plastic bearing caps. I searched everywhere. Nothing. The Limitless is different than the other 6s covers. It's longer, the motor mount is taller.
Both lowers are aluminum, but you should machine some sets to bolt onto that plate. What’s that a 24mm end mill for the radii? I’d buy a pair…
Yeah the only two plastic pieces are the insert clamps. I've taken this thing apart & in & out so many times to get the spool right, the plastic is already scarred up. I've bench tested it & I'm satisfied. Honestly man, I've been sitting here thinking I might just machine some. I have some 7075 drops. If I can get it done, it would definitely be a few sets while I'm setup. Ten is just as easy as two in a CNC. Boss em out.
Could you buy that one and use your stock aluminum top plate? I’d guess it’ll all fit together fine.
Well, yes & no. The stock one only has two holes for M3's & two offset tabs that are different shapes. I'm sure the two tapped holes in the aftermarket aluminum braces might line up on the Arrma top plate holes & tab holes. 🤔 And I'm not certain that the aluminum braces are long enough. It's possible it's for the V1, short, like Infraction & all other 6s.
