Limitless V2 spool shimm ?
justin080
Germany, Meppen
  1. Limitless
  2. Typhon 6s
  3. Typhon TLR
Should i shimm the right bearing ? You can see, it can slide on the shaft much.
I am using pps motor mount.
Do you would/ have shimmed bearing?
Camaroboy383
Invention is the mother of necessity!
Hospitality Award
Connecticut
  1. 4x4-Mega
  2. Felony
  3. Outcast 4s
  4. Outcast 6s
  5. Outcast 8s
  6. Typhon 3s
  7. Typhon 6s
Not familiar with the v2 Pinocchio spools, but I'd say it won't matter if the other bearing is in a fixed position...
Fore and aft play after install would be the determining factor if shims are needed..
justin080
Germany, Meppen
  1. Limitless
  2. Typhon 6s
  3. Typhon TLR
it has juuust a little bit of play...
but i am worried if, under load the bearing will move
idk why they made such big loosen bearingspace
real_name_hidden
Bash/Break/Fix/REPEAT 🤣
Hospitality Award
Missouri/Illinois
  1. Limitless
You can. Best bet would to ditch it
Ramjam spool should be out soon. Amazing product
Scorched has em.
Jjcustom speed as well
Camaroboy383
Hospitality Award
Connecticut
  1. 4x4-Mega
  2. Felony
  3. Outcast 4s
  4. Outcast 6s
  5. Outcast 8s
  6. Typhon 3s
  7. Typhon 6s
So that would confirm that one bearing is in a fixed position, a little play is fine, or you can shim it out...
The "floating" bearing is mostly irrelevant as it's also fixed in the mount once installed..
justin080
Germany, Meppen
  1. Limitless
  2. Typhon 6s
  3. Typhon TLR
yes the left side (front is barely play free)
Camaroboy383
Hospitality Award
Connecticut
  1. 4x4-Mega
  2. Felony
  3. Outcast 4s
  4. Outcast 6s
  5. Outcast 8s
  6. Typhon 3s
  7. Typhon 6s
Yeah it's all by design.. only one of the bearings controls the thrust or "end play" of the spool.. from an engineering and manufacturing angle it's a smart approach for a mass produced product...
Dan B.
Area man
Rig of the Month Winner
Southern Vermont
  2. Mojave EXB
  3. Outcast 6s
  4. Typhon 6s
I had to shim a Scorched spool in a PPS mount. They even include the shims. I thought this was pretty much SOP? I always shim the center whether it has a spool or a diff.
