Sounds good thanks … how far down the wire would you suggest I cut … past the “fat” part or before?Rather than use an adapter, I’d recommend cutting off that dark red adapter from your battery wire and soldering this on in its place:
E-flite Connector: EC3 Battery... https://www.amazon.com/dp/B000GXYOK8?ref=ppx_pop_mob_ap_share
One more question my esc connector has a middle slot (female end) is it alright to by pass that or do I have to find a plug that has the male end like my Nimh batteryRather than use an adapter, I’d recommend cutting off that dark red connector on your battery wire and soldering this in its place:
I wouldn’t cut much of the wire off. Just before the connector.Sounds good thanks … how far down the wire would you suggest I cut … past the “fat” part or before?
Blue “EC5” and orange “IC5” are compatible with each other. IC5 is newer and simplifies the charging process, but you have to buy spectrum smart batteries to take advantage of the benefits. They’re pricey.One more question my esc connector has a middle slot (female end) is it alright to by pass that or do I have to find a plug that has the male end like my Nimh battery
Better yet, don't cut the wire. Slice off the plastic "fat part" - but the outer layer only. This is the heat shrink. Try not to cut the cable insulation - this is the plastic coating around the wires. If you use a new exact-o blade, you can control the cut and get only the heat shrink. If you knife is dull, the heat shrink can be like a armor coating, though. Also very important - only do one wire at a time. You don't want both leads with exposed wire - this makes it easy to touch them, and this will make a BIG spark, maybe a fire, maybe damage the battery (or other equipment)Sounds good thanks … how far down the wire would you suggest I cut … past the “fat” part or before?
Right on … I completely understand now from everyone’s help here I’m blessed… my plug is actually a ic3 as labelled on plug (only realized after tips from above from other member) so I will purchase a ec3 and follow directions thank you againBetter yet, don't cut the wire. Slice off the plastic "fat part" - but the outer layer only. This is the heat shrink. Try not to cut the cable insulation - this is the plastic coating around the wires. If you use a new exact-o blade, you can control the cut and get only the heat shrink. If you knife is dull, the heat shrink can be like a armor coating, though. Also very important - only do one wire at a time. You don't want both leads with exposed wire - this makes it easy to touch them, and this will make a BIG spark, maybe a fire, maybe damage the battery (or other equipment)
Steps -
1. Cut black heat shrink.
2. De-solder black wire
3. add new heat shrink to black wire
4. Resolder Black lead to new plug (-)
5. Slide Heatshrink down over solder and shrink it with a lighter/heat gun.
Then Repeat for the red (+) wire.
When you get to step 5 and realize you skipped step 3, don't beat yourself up too bad, we have all done it... LOL
EDIT - Oh, if you are using EC5 plugs, and only have the wire insulation trimmed back to show only about 1/8" of bare wire, then you should not need heat shrink. The plug will cover the wire fine. But - make sure you snap the black wire into the plug (make it safe) before you start work on the red.
