using the spektrum s2100 so it says it’s capable of 200w. It allowed me to select the amps. Is there any other batteries capable of a faster charge rate other then 1c?1c = 1x the capacity (in mAh)/1000, so for your battery, 6A.
A 6S LiPo has a nominal voltage of 22.2V, so that would mean you need a 133W charger. If your charger has a lower power output, you may not be getting 6A, thus it will take longer.
What is your definition of 'forever'?Does anyone know what the charge rate of a gens 6000mah 6s Lipo is. I’ve been charging at 1c rate but takes forever.
Takes about a hour with a 6000mah battery. Would like to cut that in half when on the field.What is your definition of 'forever'?
What charger do you use?
Typical shopuld be ~30-45min (from storage 3.8V) if your charger is capable enough and the Lipo is healthy.
If your charger can't deliver more, a higher setting won't change anything.
You could if you charge it at 3c but only Spektrum lipos and some other ones are rated for that.Takes about a hour with a 6000mah battery. Would like to cut that in half when on the field.
Or buy another battery and charge one while using the other?Takes about a hour with a 6000mah battery. Would like to cut that in half when on the field.
Cool setup!If you want to charge fast then I think more batteries is the answer as well as a parallel charging board and a beefy charger and power supply. I have the isdt Q8 charger maxed out at 20 A charging almost 40,000 mah worth of 4s batteries here which works out to 0.5C. It takes less than 1 hr to go from storage at 3.85V to 4.2V. It would take about 3 hours to charge them each separately and that is if you are on top of changing them out as they are done:
You got the powerI've been chargin lipos since they first came to the rc world. I haven't charged at 1c in a very long time. Even if the rear battery label says 1c max. Here is my 5200mah 6s charging at 20amp. I run a 600w 30amp 24v psu and a ISDT Q8, Fairly cheap setup maybe $100 total.
This is for informational purposes, sharing my experiences. Don't blame me for burnin up your house lol. I attend my batteries when charging. View attachment 125882 View attachment 125883
Curious as to what pack your charging at nearly 4C?I've been chargin lipos since they first came to the rc world. I haven't charged at 1c in a very long time. Even if the rear battery label says 1c max. Here is my 5200mah 6s charging at 20amp. I run a 600w 30amp 24v psu and a ISDT Q8, Fairly cheap setup maybe $100 total.
Honestly, for that you get a 2nd or 3rd Lipo.
Worst thing for a Lipo is to run it until empty and hot and hook it up to a charger and do a high rate charge. Let it cool down first.
What brand and C rating of lipo do you usually run?lol I charge anything from a 650mah 3s to a 5200mah 6s at 4c. The smalls sometimes get 5 and 6c.
Ive been are part of 3 different flight clubs. LOL they don't play. We all charge at insane c ratings. And I didnt get them started on it lol. Its just what us pilots do. lol. Been doing it a long time with very minimal effect. Just like our rc's its surprising when you push the envelope what they can really take and literally be fine.
Again caution, I have used lipos since they came to the RC world and don't recommend this for a novice, but if your experienced and you don't care much about your batteries and need them now, like at the flight field, then charge away.
