I’ve ran worse myself, but I’m really cautious about giving advice based on the risk level I’m ok with.my 6s lipo battery got damaged on the corner is it ok to use still?
I would rather just buy a new can of biscuits.The entire battery isn't trashed just as a heads up, just that top cell looks to be compromised you could easily make it a 5s or 4s lipo.
Use extreme caution when doing this. I know @olds97_lss has done this a few times so he might some more insight on the ease of how to do this.
You wouldn't toss out your car because 1 wheel broke? So why toss out a perfectly good lipo because 1 cell is damaged?I would rather just buy a new can of biscuits.
I can replace a wheel easily. Without risk of fire.You wouldn't toss out your car because 1 wheel broke? So why toss out a perfectly good lipo because 1 cell is damaged?
If you pay attention to what you are doing there is no risk of fire. If you don't pay attention that is when the fit can hit the shan.I can replace a wheel easily. Without risk of fire.
Just keep your + away from your (-) and it's all good. A little electrical tape can help mitigate shorting DC.If you pay attention to what you are doing there is no risk of fire. If you don't pay attention that is when the fit can hit the shan.
This. I would charge it slowly at maybe 0.1 C and check resistance (don't leave it unattended). If all cells are equal then it is probably ok to use with caution.Personally I think just running his battery, providing all cells balance and resistance the same, is safer than getting the scissors out...
